[GRASS-user] EPSG 3035
    Moritz Lennert
    mlennert at club.worldonline.be
    Fri Mar 27 08:29:41 EDT 2009
On 27/03/09 13:05, Laura Poggio wrote:
> I will then try to upgrade the version of GRASS, but in the meantime
> just a question.
> All the files I will work on have the same projection as the location,
> at least according to gdal and using EPSG codes.
> If I create the location with the problems discussed until now and then
> import the files with -o option, would this be source of troubles for
> further elaborations such as watershed analysis?
I don't think so. But you might want to try to create a "correct"
location with all the parameters, including datum, etc. You might have
to do this by hand though, i.e. using the option to create the location
with projection parameters, instead of EPSG code or existing file.
Moritz
