[GRASS-user] azimuth of lines with v.to.db?
Maris Nartiss
maris.gis at gmail.com
Mon Mar 30 08:36:48 EDT 2009
Hello all.
I also needed to do some lineament orientation analysis and to do so I
modified v.to.db [1]. Now it supports calculating line azimuths as CW
direction from line start point to line endpoint.
Usage example:
v.to.db map=lineaments type=line option=azimuth units=degrees
columns=orientation
svn up Your develbranch6 and test it :)
Maris.
1. http://trac.osgeo.org/grass/changeset/36528
