[GRASS-user] i.landsat.acca, i.landsat.toar don't work under
	grass-6.5.svn & Ubuntu Jaunty 64-bit
    Markus Neteler
    neteler at osgeo.org
    Fri May  1 01:03:05 EDT 2009
On Fri, May 1, 2009 at 4:45 AM, Nikos Alexandris
<nikos.alexandris at felis.uni-freiburg.de> wrote:
> Following error messages when trying to work with... :
> i.landsat.acca help
> ERROR: Incompatible library version for module
> i.landsat.toar help
"make distclean" is your friend.
Typically:
You need to recompile GRASS completely, also these
modules if that message appears (means that a library
change was done in SVN which requires recompilation).
Markus
