[GRASS-user] i.landsat.acca, i.landsat.toar don't work under
grass-6.5.svn & Ubuntu Jaunty 64-bit
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Fri May 1 05:13:24 EDT 2009
Nikos:
> > Following error messages when trying to work with... :
> > i.landsat.acca help
> > ERROR: Incompatible library version for module
> > i.landsat.toar help
Markus:
> "make distclean" is your friend.
> Typically:
> You need to recompile GRASS completely, also these
> modules if that message appears (means that a library
> change was done in SVN which requires recompilation).
Yes, I did. They don't work after a complete recompilation of
grass-6.5.svn. I 'll give it another try though.
Thanks, Nikos
