[GRASS-user] i.landsat.acca, i.landsat.toar don't work under
	grass-6.5.svn & Ubuntu Jaunty 64-bit
    Nikos Alexandris
    nikos.alexandris at felis.uni-freiburg.de
    Fri May  1 06:58:25 EDT 2009
On Fri, 2009-05-01 at 11:13 +0200, Nikos Alexandris wrote:
> Nikos:
> > > Following error messages when trying to work with... :
> > > i.landsat.acca help
> > > ERROR: Incompatible library version for module
> > > i.landsat.toar help
> Markus:
> > "make distclean" is your friend.
> > Typically:
> > You need to recompile GRASS completely, also these
> > modules if that message appears (means that a library
> > change was done in SVN which requires recompilation).
> Yes, I did. They don't work after a complete recompilation of
> grass-6.5.svn. I 'll give it another try though.
OK, I repeated again the same as I did before but _without_ compiling no
other grass-addons than those two mentioned above. Now it works.
Thanks, Nikos
