[GRASS-user] installing grass trunk to jaunty
    maning sambale
    emmanuel.sambale at gmail.com
    Fri May  1 03:17:08 EDT 2009
mitch,
This works for me without a hitch! thanks!
On Thu, Apr 30, 2009 at 3:53 AM, mitch <reflexeos at yahoo.it> wrote:
> hi maning, i haven't been playing so much with it (busy)
> but i got grass7 svn work on jaunty
> gdal and proj from synaptic
> DEPENDENCIES
> sudo apt-get install build-essential \
> flex \
> lesstif2-dev \
> libfftw3-dev \
> libglu1-mesa-dev \
> libglu1-xorg-dev \
> libpng12-dev \
> libpq-dev \
> unixodbc-dev \
> doxygen \
> libmysqlclient15-dev \
> graphviz \
> libcairo2-dev \
> bison \
> libncurses5-dev \
> zlib1g-dev \
> libjpeg62-dev \
> libgdal1-dev \
> libtiff4-dev \
> libgcc1 \
> tcl8.4-dev \
> tk8.4-dev \
> fftw3-dev \
> libfreetype6-dev \
> libavcodec-dev \
> libxmu-dev \
> libreadline5 \
> libreadline5-dev \
> python2.5-dev \
> python-wxversion \
> swig \
> libwxbase2.8-0 \
> libwxbase2.8-dbg \
> libwxbase2.8-dev \
> libwxgtk2.8-0 \
> libwxgtk2.8-dbg \
> libwxgtk2.8-dev \
> python-wxgtk2.8 \
> wx2.8-doc \
> wx2.8-examples \
> wx2.8-headers \
> wx2.8-i18n \
> python-numpy \
> sqlite3 \
> libsqlite3-dev \
> python-opengl
> svn checkout https://svn.osgeo.org/grass/grass/trunk grass_trunk
> (wherever you want...i did it in /usr/local/src)
> CFLAGS="-g -Wall" ./configure \
> --with-gdal=/usr/local/bin \
> -with-tcltk-includes=/usr/include/tcl8.4 \
> --with-sqlite \
> --with-cxx \
> --with-fftw \
> --with-freetype=yes \
> --with-freetype-includes=/usr/include/freetype2 \
> --with-readline \
> --with-opengl-includes=/usr/include/GL \
> --with-python=/usr/bin/python2.5-config \
> --with-wxwidgets=/usr/bin/wx-config \
> --enable-largefile=yes \
> --with-proj-includes=/usr/include \
> --with-proj-share=/usr/share/proj \
> --with-proj-libs=/usr/lib
> GRASS is now configured for:  i686-pc-linux-gnu
>  Source directory:            /usr/local/src/grass_trunk
>  Build directory:             /usr/local/src/grass_trunk
>  Installation directory:      ${prefix}/grass-7.0.svn
>  Startup script in directory: ${exec_prefix}/bin
>  C compiler:                  gcc -g -Wall
>  C++ compiler:                c++ -g -O2
>  Building shared libraries:   yes
>  64bit support:               no
>  OpenGL platform:             X11
>  MacOSX application:         no
>  NVIZ:                       yes
>  BLAS support:               no
>  C++ support:                yes
>  Cairo support:              yes
>  DWG support:                no
>  FFMPEG support:             no
>  FFTW support:               yes
>  FreeType support:           yes
>  GDAL support:               yes
>  GEOS support:               no
>  JPEG support:               yes
>  LAPACK support:             no
>  Large File support (LFS):   yes
>  MySQL support:              no
>  NLS support:                no
>  ODBC support:               no
>  OGR support:                yes
>  OpenGL support:             yes
>  PNG support:                yes
>  PostgreSQL support:         no
>  Python support:             yes
>  Readline support:           yes
>  SQLite support:             yes
>  Tcl/Tk support:             yes
>  wxWidgets support:          yes
>  TIFF support:               yes
>  X11 support:                yes
>  Regex support:              yes
>  POSIX thread support:       no
> sudo make
> Errors in:
> No errors detected.
> (hopefully :-))
> sudo make install
> this is what i did (indeed you can change parameters in ./configure)
> ....btw community, AM I RIGHT?...did i miss something or include to
> much? :-) (suggestion appreciated)
> another question:
> what do i have to do exactly to update?
> svn up
> ./configure (including the same parameters of the previous
> installation?)
> make
> make install (again?)
> ..or there is another way to do it?
> cheers,
> mitch
> On Thu, 2009-04-30 at 01:28 +0800, maning sambale wrote:
>> Compiling from source following:
>> http://grass.osgeo.org/wiki/Compile_and_Install#Ubuntu
>> I am somehow stuck here:
>> ./configure --enable-gpl --enable-libvorbis --enable-libtheora \
>>             --enable-liba52 --enable-libdc1394 --enable-libgsm \
>>             --enable-libmp3lame --enable-libfaad --enable-libfaac \
>>             --enable-libxvid --enable-pthreads --enable-libx264 \
>>             --enable-shared
>> Unknown option "--enable-liba52".
>> See ./configure --help for available options.
>> ps.
>> in the GRASS dependencies:
>> I think "bpng12-dev" should be "libpng12-dev"
>> sudo apt-get install grass build-essential flex bison libncurses5-dev
>> zlib1g-dev \
>> libjpeg62-dev libgdal1-dev libtiff4-dev libgcc1 bpng12-dev tcl8.4-dev
>> tk8.4-dev fftw3-dev \
>> libfreetype6-dev libavcodec-dev libxmu-dev gdal-bin libreadline5
>> libreadline5-dev \
>> make python-dev python-wxversion swig
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
