[GRASS-user] installing grass trunk to jaunty
    mitch
    reflexeos at yahoo.it
    Sat May  2 10:17:03 EDT 2009
On Fri, 2009-05-01 at 15:17 +0800, maning sambale wrote:
> mitch,
> This works for me without a hitch! thanks!
sure...anytime!
Now I have a problem though:
I was curious and I updated to revision 36943.
I had a couple of errors in compilation
Errors in:
/usr/local/src/grass_trunk/gui/wxpython/vdigit
/usr/local/src/grass_trunk/gui/wxpython/nviz
make in those folders didn't work.
I remember that I updated from python2.5 to 2.6
(and this sounds like a python problem, doesn't it?)
The update manager didn't install python2.6-dev
so I did it manually and changed the configure parameter
from --with-python=/usr/bin/python2.5-config
to --with-python=/usr/bin/python2.6-config
now it compiles (although the shell reads many "warning messages"
and it kind of gets stuck on NVIZ and VDIGIT)
and I end up with:
Errors in:
No errors detected.
..I can install it but NVIZ and VDIGIT don't work!
..well...they don't work well:
NVIZ starts but when I drag the display window it goes blank.
The shell reads:
GRASS 7.0.svn (nc_spm_08):/usr/local/src/grass_trunk > get fences
failed: -1
param: 6, val: 0
Any idea of why does this happen?
cheers,
mitch.
> On Thu, Apr 30, 2009 at 3:53 AM, mitch <reflexeos at yahoo.it> wrote:
> > hi maning, i haven't been playing so much with it (busy)
> > but i got grass7 svn work on jaunty
> > gdal and proj from synaptic
> > DEPENDENCIES
> > sudo apt-get install build-essential \
> > flex \
> > lesstif2-dev \
> > libfftw3-dev \
> > libglu1-mesa-dev \
> > libglu1-xorg-dev \
> > libpng12-dev \
> > libpq-dev \
> > unixodbc-dev \
> > doxygen \
> > libmysqlclient15-dev \
> > graphviz \
> > libcairo2-dev \
> > bison \
> > libncurses5-dev \
> > zlib1g-dev \
> > libjpeg62-dev \
> > libgdal1-dev \
> > libtiff4-dev \
> > libgcc1 \
> > tcl8.4-dev \
> > tk8.4-dev \
> > fftw3-dev \
> > libfreetype6-dev \
> > libavcodec-dev \
> > libxmu-dev \
> > libreadline5 \
> > libreadline5-dev \
> > python2.5-dev \
> > python-wxversion \
> > swig \
> > libwxbase2.8-0 \
> > libwxbase2.8-dbg \
> > libwxbase2.8-dev \
> > libwxgtk2.8-0 \
> > libwxgtk2.8-dbg \
> > libwxgtk2.8-dev \
> > python-wxgtk2.8 \
> > wx2.8-doc \
> > wx2.8-examples \
> > wx2.8-headers \
> > wx2.8-i18n \
> > python-numpy \
> > sqlite3 \
> > libsqlite3-dev \
> > python-opengl
> > svn checkout https://svn.osgeo.org/grass/grass/trunk grass_trunk
> > (wherever you want...i did it in /usr/local/src)
> > CFLAGS="-g -Wall" ./configure \
> > --with-gdal=/usr/local/bin \
> > -with-tcltk-includes=/usr/include/tcl8.4 \
> > --with-sqlite \
> > --with-cxx \
> > --with-fftw \
> > --with-freetype=yes \
> > --with-freetype-includes=/usr/include/freetype2 \
> > --with-readline \
> > --with-opengl-includes=/usr/include/GL \
> > --with-python=/usr/bin/python2.5-config \
> > --with-wxwidgets=/usr/bin/wx-config \
> > --enable-largefile=yes \
> > --with-proj-includes=/usr/include \
> > --with-proj-share=/usr/share/proj \
> > --with-proj-libs=/usr/lib
> > GRASS is now configured for:  i686-pc-linux-gnu
> >  Source directory:            /usr/local/src/grass_trunk
> >  Build directory:             /usr/local/src/grass_trunk
> >  Installation directory:      ${prefix}/grass-7.0.svn
> >  Startup script in directory: ${exec_prefix}/bin
> >  C compiler:                  gcc -g -Wall
> >  C++ compiler:                c++ -g -O2
> >  Building shared libraries:   yes
> >  64bit support:               no
> >  OpenGL platform:             X11
> >  MacOSX application:         no
> >  NVIZ:                       yes
> >  BLAS support:               no
> >  C++ support:                yes
> >  Cairo support:              yes
> >  DWG support:                no
> >  FFMPEG support:             no
> >  FFTW support:               yes
> >  FreeType support:           yes
> >  GDAL support:               yes
> >  GEOS support:               no
> >  JPEG support:               yes
> >  LAPACK support:             no
> >  Large File support (LFS):   yes
> >  MySQL support:              no
> >  NLS support:                no
> >  ODBC support:               no
> >  OGR support:                yes
> >  OpenGL support:             yes
> >  PNG support:                yes
> >  PostgreSQL support:         no
> >  Python support:             yes
> >  Readline support:           yes
> >  SQLite support:             yes
> >  Tcl/Tk support:             yes
> >  wxWidgets support:          yes
> >  TIFF support:               yes
> >  X11 support:                yes
> >  Regex support:              yes
> >  POSIX thread support:       no
> > sudo make
> > Errors in:
> > No errors detected.
> > (hopefully :-))
> > sudo make install
> > this is what i did (indeed you can change parameters in ./configure)
> > ....btw community, AM I RIGHT?...did i miss something or include to
> > much? :-) (suggestion appreciated)
> > another question:
> > what do i have to do exactly to update?
> > svn up
> > ./configure (including the same parameters of the previous
> > installation?)
> > make
> > make install (again?)
> > ..or there is another way to do it?
> > cheers,
> > mitch
> > On Thu, 2009-04-30 at 01:28 +0800, maning sambale wrote:
> >> Compiling from source following:
> >> http://grass.osgeo.org/wiki/Compile_and_Install#Ubuntu
> >> I am somehow stuck here:
> >> ./configure --enable-gpl --enable-libvorbis --enable-libtheora \
> >>             --enable-liba52 --enable-libdc1394 --enable-libgsm \
> >>             --enable-libmp3lame --enable-libfaad --enable-libfaac \
> >>             --enable-libxvid --enable-pthreads --enable-libx264 \
> >>             --enable-shared
> >> Unknown option "--enable-liba52".
> >> See ./configure --help for available options.
> >> ps.
> >> in the GRASS dependencies:
> >> I think "bpng12-dev" should be "libpng12-dev"
> >> sudo apt-get install grass build-essential flex bison libncurses5-dev
> >> zlib1g-dev \
> >> libjpeg62-dev libgdal1-dev libtiff4-dev libgcc1 bpng12-dev tcl8.4-dev
> >> tk8.4-dev fftw3-dev \
> >> libfreetype6-dev libavcodec-dev libxmu-dev gdal-bin libreadline5
> >> libreadline5-dev \
> >> make python-dev python-wxversion swig
