[GRASS-user] Re: r.recode does not recognise fourth routine
A. Márcia BARBOSA barbosa at uevora.pt
Wed May 6 07:28:42 EDT 2009
[sorry if I didn't properly reply to the list last times, it was accidental]
Actually, searching through the bug list I found the reason: "#172:
r.recode truncates last character in rules file". As I was recoding
the rasters to one-digit values, the last value was read as nothing,
hence the '1700:*:' is not a valid rule.
It works when I add an extra digit to the last value in the rules file
(which is not read), as suggested in the bug ticket. And apparently
this is only necessary when getting the rules from a file rather than
typing them in the command line, although I couldn't quite find out
how to type the rules in the command line... or rather how to say I've
typed the last rule already.
Cheers,
Márcia
