[GRASS-user] v.net.path weight & co
Stefano elstefen at gmail.com
Fri May 8 14:58:49 EDT 2009
Thanks.
i found a person that has already modfied the v.net.path as i want to do, so
i'll try.
if i'm able to found a solution i'll post here.
thanks folks
On Fri, May 8, 2009 at 20:36, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, May 8, 2009 at 12:23 PM, Stefano <elstefen at gmail.com> wrote:
> > where i can found the code of v.net.path ?
> Here you can find it online (apart from the source code packages):
> http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/vector/v.net.path/
> Please post your findings.
> Markus
Stefano
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090508/7bbe6ae3/attachment.html
