[GRASS-user] Point count with large vectors
    Benjamin Ducke
    benjamin.ducke at oxfordarch.co.uk
    Tue May 12 04:30:11 EDT 2009
Don't know if that will speed things up, but you could try
buffering all points in B by a given distance, then use
this to count the points in A that are inside the buffer polygons:
http://grass.osgeo.org/wiki/GRASS_AddOns#v.count.points.sh
You could still do as Hamish suggested to reduce the set of
points to test a priori.
Ben
Hamish wrote:
> Richard wrote:
>>>> I have two large points files (>20,000 sites), and I want to
>>>> find the number of points in A falling within a given distance
>>>> of the points in B.
>>>> I can use a buffer from Map A and run v.distance, but it takes an
>>>> extremely long time, so suggestions would be welcome!
>> As to "a long time", I left one loop running for several
>> days and only completed
>> one state of Australia!
> to speed it up perhaps v.buffer + v.select could be used as a
> pre-processing step to remove any points which are too far from both
> A and B? maybe v.buffer for both A and B, v.overlay those two together,
> then v.select only A and B points in that area, and finally run
> v.distance for only the reduced list of points?
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Benjamin Ducke
Senior Geospatial Consultant
Oxford Archaeology
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
