[GRASS-user] RE:How to find shortest distances from the investigation point to the shoreline
sgw00412 at nifty.com sgw00412 at nifty.com
Wed May 13 01:00:26 EDT 2009
Hi all
I'm sorry for repeating the same question.
I tested by two kinds of geographical coordinate systems by using the same dat
a.
One of the geographical coordinate systems is UTM54, and the remainder is wgs8
4.
data :point vector data (10 points) and a line vector data
OS: grass 6.2.3 on Cygwin.
As a result, the case of UTM54 obtained the distance of meter. On the other ha
nd, wgs84 obtained the distance of decimal value.
So, I guess that the decimal value of wgs84 is a degree of latitude longitude.
Grass manual wrote that "...In lat-long locations v.distance gives distances (
dist and to_along) in meters not in degrees calculated as geodesic distances o
n a sphere.."
http://www.ces.iisc.ernet.in/grass/grass64/manuals/html64_user/v.distance.html
Though this manual is version 6.4, the manual of version 6.2 is not written it
Is this interpretation correct?
If it is so, please teach me the method of converting the decimal value into t
he meter.
PROJCS["Transverse Mercator",
    GEOGCS["unnamed",
        DATUM["unknown",
            SPHEROID["unnamed",6378137,298.257222101],
            TOWGS84[0,0,0,0,0,0,0]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",141],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1]]
cat,UserID,distance
1,0,324.231475
2,0,170.339585
3,0,338.095708
4,0,347.756189
5,0,143.91159
6,0,156.702461
7,0,336.369666
8,0,178.761379
9,0,163.440513
10,0,122.997484
GEOGCS["wgs84",
    DATUM["WGS_1984",
        SPHEROID["wgs84",6378137,298.257223563]],
cat,UserID,distance
1,0,0.003779
2,0,0.00198
3,0,0.003937
4,0,0.004053
5,0,0.001677
6,0,0.001826
7,0,0.003048
8,0,0.002084
9,0,0.001484
10,0,0.001113
Yasuo shimada
