[GRASS-user] problem with v.clean and intersection pts
    hardinej
    hardinej at gmail.com
    Fri May 15 12:56:06 EDT 2009
Hey thanks a lot. you were right. I should have omitted the first couple of
lines. They were to make a bunch of parallel transects across the shoreline.
I should have used v.segment but I was having problems so I just did that.
But anyway, I ran v.build on the transects and and then the v.clean trick
worked.
Thanks again,
Eric
View this message in context: http://n2.nabble.com/problem-with-v.clean-and-intersection-pts-tp2887675p2908835.html
Sent from the Grass - Users mailing list archive at Nabble.com.
