[GRASS-user] problem with v.clean and intersection pts
    Maris Nartiss
    maris.gis at gmail.com
    Sun May 17 16:18:17 EDT 2009
Hello,
if You are working with transects, You may take a look at v.profile
add-on [1]. It will print distance from line start point to any point
on line or line intersection. It's really useful tool for GIS data
conversation to chart friendly data.
Maris.
1. http://svn.osgeo.org/grass/grass-addons/vector/v.profile/
2009/5/15 hardinej <hardinej at gmail.com>:
> Hey thanks a lot. you were right. I should have omitted the first couple of
> lines. They were to make a bunch of parallel transects across the shoreline.
> I should have used v.segment but I was having problems so I just did that.
> But anyway, I ran v.build on the transects and and then the v.clean trick
> worked.
> Thanks again,
> Eric
> View this message in context: http://n2.nabble.com/problem-with-v.clean-and-intersection-pts-tp2887675p2908835.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
