[GRASS-user] gis.m error
    Milton Cezar Ribeiro
    miltinho.astronauta at gmail.com
    Sun May 17 19:01:15 EDT 2009
Hi Seb,
Give a little bit more information about the system you are running grass.
Command lines works ok, I suppose.
By the way, its appears that you are importing world wide maps. Are you
importing bioclimatic maps for species distribution modeling? Case yes, we
can change some ideas off-topic.
Cheers
milton
brazil=toronto
2009/5/17 Seb <spluque at gmail.com>
> Hi,
> With SVN GRASS 6.5 (built today), starting gis.m gave this error:
> ---<--------------------cut here---------------start------------------->---
> GRASS 6.5.svn > gis.m&
> [1] 26944
> [1]+  Done                    gis.m
> GRASS 6.5.svn > Error in startup script: can't read "prj(name)": no such
> variable
>    while executing
> "string eq "Lat/Lon" "$prj(name)""
>    (procedure "MapCanvas::get_mapunits" line 30)
>    invoked from within
>    (procedure "MapCanvas::currentzoom" line 11)
>    invoked from within
> "MapCanvas::currentzoom $mon"
>    (procedure "MapCanvas::coordconv" line 23)
>    invoked from within
> "MapCanvas::coordconv $mon"
>    (procedure "MapCanvas::create" line 68)
>    invoked from within
> "MapCanvas::create"
>    (procedure "Gm::startmon" line 11)
>    invoked from within
> "Gm::startmon"
>    (procedure "Gm::create" line 79)
>    invoked from within
> "Gm::create"
>    (procedure "main" line 30)
>    invoked from within
> "main $argc $argv"
>    (file
> "/usr/local/src/grass-svn/dist.x86_64-unknown-linux-gnu/etc/gm/gm.tcl" line
> 566)
> ---<--------------------cut here---------------end--------------------->---
> The error only occurs in a XY location with these details:
> GRASS 6.5.svn > g.region -p
> projection: 0 (x,y)
> zone:       0
> north:      90
> south:      -90
> west:       -180
> east:       180
> nsres:      1
> ewres:      1
> rows:       180
> cols:       360
> cells:      64800
> I see no problems in other locations.
> Cheers,
> Seb
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090517/465eb830/attachment.html
