[GRASS-user] r.series g.mlist unhappy together
saewan koh saewan at gmail.com
Wed May 20 15:58:26 EDT 2009
Hi Markus,
On 20-May-09, at 1:48 PM, Markus Neteler wrote:
> Hi Saewan,
> On Wed, May 20, 2009 at 8:51 PM, saewan koh <saewan at gmail.com> wrote:
>> The last weird thing i just discovered is that when i use g.mlist
>> on its own
>>  - it will not run if i use quotations as in g.mlist rast
>> pat="SmrDDT0Tot*"
> What happens exactly?
When i run
g.mlist pattern="*1986*dd5s"
I get the following output.
(Wed May 20 13:49:57 2009) Command finished (0 sec)
If i run g.mlist pattern=*1986*dd5s
1986_4_12_4_18_dd5s
1986_4_19_4_25_dd5s
1986_4_26_5_2_dd5s
1986_4_5_4_11_dd5s
etc.
>> It does run if i use g.mlist rast pat=SmrDDT0Tot*
>> So i wonder if my issue is something in the way the script is
>> running within
>> the shell.
> At this point I wonder which shell you are using... what does
> echo $SHELL
> say?
In my terminal when for the above command i get the response of:
-bash: echo/bin/bash: No such file or directory
I am in the wrong shell?
I really really appreciate all this help.
Thanks,
Saewan
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090520/9668730f/attachment.html
