[GRASS-user] r.series g.mlist unhappy together
Markus Neteler
neteler at osgeo.org
Wed May 20 15:48:16 EDT 2009
Hi Saewan,
On Wed, May 20, 2009 at 8:51 PM, saewan koh <saewan at gmail.com> wrote:
> The last weird thing i just discovered is that when i use g.mlist on its own
> - it will not run if i use quotations as in g.mlist rast pat="SmrDDT0Tot*"
What happens exactly?
> It does run if i use g.mlist rast pat=SmrDDT0Tot*
> So i wonder if my issue is something in the way the script is running within
> the shell.
At this point I wonder which shell you are using... what does
echo $SHELL
say?
Markus
