[GRASS-user] Vector layers > Photoshop
Nick Cahill
ndcahill at wisc.edu
Fri May 29 09:23:51 EDT 2009
Dear Aaron,
I've used ps.map to do this - it will produce a postscript file that
most pdf/postscript aware programs can read. I have used Adobe
Illustrator with more success than Photoshop for modifying such files.
Nick Cahill
On May 29, 2009, at 4:06 PM, Aaron Bonding wrote:
> I'm more or less a noob to Grass and GIS (graphic designer by trade
> and a
> mapophile by hobby), so please forgive my ignorance. I'm working in
> Grass
> 6.2.1 (OpenOSX via X11) if that helps.
> I have a shaded raster DEM as a base and several simple vector
> layers. I can
> easily export this raster as a TIFF, but I also need the vector layers
> exported to a format that Photoshop can read. I've been largely
> unsuccessful
> in converting the vector layers to raster with v.to.rast (then the
> raster to
> TIFF). Is there a step I'm missing that would make this easier?
> It seems like I need to convert to raster first so they will fit on
> top of
> each other without much work in Photoshop, ie. each layer > TIFF,
> then just
> have each TIFF as a layer.
> View this message in context: http://n2.nabble.com/Vector-layers-%3E-Photoshop-tp2993749p2993749.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
