[GRASS-user] Re: Importing lines from database
Seb
spluque at gmail.com
Fri May 29 14:57:07 EDT 2009
On Fri, 29 May 2009 10:20:33 -0700 (PDT),
Hamish <hamish_b at yahoo.com> wrote:
> Seb wrote:
>> Is this still the best solution for creating lines from a points
>> ASCII file? So assuming one has an ASCII file like:
>> ---<--------------------cut
here---------------start-------------------> ---
id> X|Y
AGB-08-0001> -4.44|22.06 -5.90|20.17 -5.03|17.49 -5.03|18.16
AGB-08-0002> -4.44|22.06 -5.90|20.17 -5.03|17.49
AGB-08-0003> -4.44|22.06 -5.90|20.17
here---------------end---------------------> ---
>> and we'd like to create lines for each code in the "id" column, we'd
>> have to reformat the file so that it conforms to the "standard" GRASS
>> format for ASCII lines files? If so, it seems we'd also need to
>> recode such an "id" column into integer, so that it can be used as
>> category. Or perhaps there is a better approach to importing this
>> kind of data that are typical in animal tracking studies, where
>> coordinates correspond to measurements taken at sequential times for
>> each animal (id)? Thanks in advance for any input.
> it's pretty easy to get that into 'v.in.mapgen -f' format, but
> attaching the labels might be a pain so maybe the awk script (if you
> can get your head around it) is easier way after all??.
> here's a little script to do it:
> # script to load in data file, then make into lines based on unique #
> first column
> INFILE="animal_track.dat" OUTFILE="animal_track.asc" MAPNAME=`echo
> "$OUTFILE" | cut -f1 -d.`
> ANIMALS=`grep ^AGB "$INFILE" | cut -f1 -d'|' | sort | uniq` echo "nan
> nan" > "$OUTFILE" \rm "${OUTFILE}.table"
> i=0 for CRITTER in $ANIMALS ; do i=`expr $i + 1` grep -w "$CRITTER"
> "$INFILE" | \ awk -F'|' '{print $2 " "$3}' >> "$OUTFILE"
> echo "nan nan" >> "$OUTFILE"
> echo "$i|$CRITTER" >> "${OUTFILE}.table" done
> v.in.mapgen -f in="$OUTFILE" out="${MAPNAME}_import" v.category
> in="${MAPNAME}_import" out="$MAPNAME" option=add g.remove
> vect="${MAPNAME}_import"
> v.db.addtable "$MAPNAME" column="label varchar(25)"
> ## slow while read LINE ; do CAT=`echo "$LINE" | awk -F'|' '{print
> $1}'` LABEL=`echo "$LINE" | awk -F'|' '{print $2}'` v.db.update
> map="$MAPNAME" column=label value="$LABEL" where="cat = $CAT" done <
> "${OUTFILE}.table"
> ## or, faster sed -e "s/^/INSERT INTO $MAPNAME (cat,label) values (/"
> \ -e "s/|/,'/" \ -e "s/$/');/" "${OUTFILE}.table" | db.execute
> # another fast, but how to correctly quote ''? awk -F'|' -v
> MAPNAME=$MAPNAME \ '{print "INSERT INTO " MAPNAME " (cat,label) values
> (" $1 ",\'" $2 "\');" }' \ "${OUTFILE}.table" | db.execute
> # all done
> hopefully not too badly linewrapped by yahoo's helpfulness.
> ok, still not very simple, but given free-form input data it is hard
> to tell the computer what you want.
So IIUC, it's not possible to keep attributes for each point along a
lines vector, so that one can select points along a line that meet
certain criteria. For example, to be able to show (or do calculations)
a line joining points that are have values "A" in column 3 and values
"Z" in column 4. Thanks.
Seb
