[GRASS-user] Re: Importing lines from database
Moritz Lennert mlennert at club.worldonline.be
Sat May 30 11:41:13 EDT 2009
On 29/05/09 20:57, Seb wrote:
> On Fri, 29 May 2009 10:20:33 -0700 (PDT),
> Hamish <hamish_b at yahoo.com> wrote:
>> Seb wrote:
>>> Is this still the best solution for creating lines from a points
>>> ASCII file?
In grass7, you also have 'v.net ... operation=arcs' (thanks to Martin
Landa) to which you feed an existing points file and a file with the
following information:
[category of edge] [category of start node] [category of end node]
Hasn't received much testing I think, but if it does, it could probably
be backported to grass6.5.
Moritz.
