[GRASS-user] error importing postgresql db
    Nikos Alexandris
    nikos.alexandris at felis.uni-freiburg.de
    Sun May 31 18:54:05 EDT 2009
Seb:
> I tried importing a PostgreSQL table (a view) using v.in.ogr.  However,
> the module failed
> The warning about the sex column is harmless since it is just a custom
> type and the 255 limit is fine here.  The parsing error with time column
> seems to have prevented the vector from building properly though.  The
> same error occurs when doing it with v.in.db.  The view and the
> underlying tables show no problems in Postgresql.
Not sure if this is a conflict with SQL commands, but you could try to
_feed_ new names for your columns by using the "cname=" paramater of
"v.in.ogr" and see what happens?
Nikos
