[GRASS-user] Re: error importing postgresql db
Seb spluque at gmail.com
Sun May 31 19:50:41 EDT 2009
On Mon, 01 Jun 2009 00:54:05 +0200,
Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de> wrote:
> Seb:
>> I tried importing a PostgreSQL table (a view) using v.in.ogr.
>> However, the module failed
>> The warning about the sex column is harmless since it is just a
>> custom type and the 255 limit is fine here.  The parsing error with
>> time column seems to have prevented the vector from building properly
>> though.  The same error occurs when doing it with v.in.db.  The view
>> and the underlying tables show no problems in Postgresql.
> Not sure if this is a conflict with SQL commands, but you could try to
> _feed_ new names for your columns by using the "cname=" paramater of
> "v.in.ogr" and see what happens?
I tried that but the problem remains.  It seems as if there's problems
importing such datetime columns.  Thanks.
Seb
