[GRASS-user] NVIZ - Visualization of buildings
incanus
andresfr at unizar.es
Wed Nov 4 04:30:36 EST 2009
Thanx to Markus I get this:
http://n2.nabble.com/file/n3943983/trozoNVIZ.png
As everyone can see, the "walls" are transparent. I've tried to resample the
color file to the resolution of the elevation file, and the result is the
same.
I would appreciate any comment os suggest about this, if someone had seen
something similar.
thanx,
Andres
Markus Neteler wrote:
> On Sun, Nov 1, 2009 at 5:46 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Fri, Oct 30, 2009 at 10:24 AM, incanus <andresfr at unizar.es> wrote:
>>> Hi everyone,
>>> I'm trying to visualize a DEM that I've generated of the buildings of a
>>> city. In each cell I have the meters of elevation. When I try to see it
>>> with
>>> NVIZ I found that it makes something like interpolation, smoothing the
>>> corners like it was a DEM of terrain instead of "hard edges" (i don't
>>> know
>>> how to say it).
>> For speed reasons, NVIZ is per default (typically) starting with a
>> reduced visualization.
>> To increase that:
>> Menu: Visualize -> Raster Surface -> Resolution | fine: XXX
>> The smaller XXX, the higher the shown resolution.
>> When XXX=1, then the full resolution as defined by g.region is
>> used.
> Forgot to mention: some examples here (made without much efforts):
> # only Lidar-based DSM + orthophoto:
> http://gis.fem-environment.eu/
> # Foto versus Lidar-based DSM + orthophoto (nviz)
> http://gis.fem-environment.eu/gis-analysis/
> cheers
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/NVIZ-Visualization-of-buildings-tp3917825p3943983.html
Sent from the Grass - Users mailing list archive at Nabble.com.
