[GRASS-user] NVIZ - Visualization of buildings
incanus
andresfr at unizar.es
Wed Nov 4 04:53:06 EST 2009
Forget it! and thanx again Markus,
finally, I remember that in my DEM there was 0-values and null-values.
I replaced the null's by 0's and it works perfect!
incanus wrote:
> Thanx to Markus I get this:
> http://n2.nabble.com/file/n3943983/trozoNVIZ.png
> As everyone can see, the "walls" are transparent. I've tried to resample
> the color file to the resolution of the elevation file, and the result is
> the same.
> I would appreciate any comment os suggest about this, if someone had seen
> something similar.
> thanx,
> Andres
> Markus Neteler wrote:
>> On Sun, Nov 1, 2009 at 5:46 PM, Markus Neteler <neteler at osgeo.org> wrote:
>>> On Fri, Oct 30, 2009 at 10:24 AM, incanus <andresfr at unizar.es> wrote:
>>>> Hi everyone,
>>>> I'm trying to visualize a DEM that I've generated of the buildings of a
>>>> city. In each cell I have the meters of elevation. When I try to see it
>>>> with
>>>> NVIZ I found that it makes something like interpolation, smoothing the
>>>> corners like it was a DEM of terrain instead of "hard edges" (i don't
>>>> know
>>>> how to say it).
>>> For speed reasons, NVIZ is per default (typically) starting with a
>>> reduced visualization.
>>> To increase that:
>>> Menu: Visualize -> Raster Surface -> Resolution | fine: XXX
>>> The smaller XXX, the higher the shown resolution.
>>> When XXX=1, then the full resolution as defined by g.region is
>>> used.
>> Forgot to mention: some examples here (made without much efforts):
>> # only Lidar-based DSM + orthophoto:
>> http://gis.fem-environment.eu/
>> # Foto versus Lidar-based DSM + orthophoto (nviz)
>> http://gis.fem-environment.eu/gis-analysis/
>> cheers
>> Markus
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/NVIZ-Visualization-of-buildings-tp3917825p3944115.html
Sent from the Grass - Users mailing list archive at Nabble.com.
