SV: [GRASS-user] grid legend
Martin Album Ytre-Eide
Martin.Album.Ytre-Eide at nrpa.no
Fri Nov 13 08:07:42 EST 2009
d.grid does not seem to accept color=none . I am sorry, but I was not able find the function ps.out.
A solution could be to use d.graph together with d.region.box (thank you, I found it at wiki addons) . Then I will have to make shell-script to generate the coordinates I want to use.
I just thought there was an easier solution, since it seems to be done by others (http://www.valledemexico.ambitiouslemon.com/gallery.html).
Martin
________________________________________
Fra: Hamish [hamish_b at yahoo.com]
Sendt: 13. november 2009 05:59
Til: grass-user at lists.osgeo.org; Martin Album Ytre-Eide
Emne: Re: [GRASS-user] grid legend
try d.grid with grid line color set to "none", and especially ps.out from
wiki addons.
Hamish
--- On Wed, 11/11/09, Martin Album Ytre-Eide wrote:
> From: Martin Album Ytre-Eide <Martin.Album.Ytre-Eide at nrpa.no>
> Subject: [GRASS-user] grid legend
> To: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
> Date: Wednesday, November 11, 2009, 1:40 AM
> Hello.
> I wont to do something similar to what is done in:
> http://www.gdf-hannover.de/lit_html/grass60_v1.2_en/node81.html
> in figure 36 and 38 (processing figures with xfig). Having
> a figure where you could see the coordinates of your points
> The problem is to generate x and y-axes with numbers,
> surrounding the map.
> d.grid gives something similar, but I cant seem to turn of
> the grid lines and the numbers are "inside" the map.
> tried ps.map, but can't move the numbers outside the
> x and y lines (see attachment)
> If anyone has any suggestions how to do this or know how
> this is done with xfig, I would appreciate it.
> Thanks.
> Martin Ytre-Eide
