[GRASS-user] Data Import and Coordinate Information
M S
mseibel at gmail.com
Sat Nov 14 19:37:14 EST 2009
If I can help, please let me know. But the parameter mapping from
the E$RI to GRASS was fairly straightforward.
For all the themes being imported into a new location, are they all
different projections?
Mark
On Sat, Nov 14, 2009 at 7:25 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Sat, 14 Nov 2009, M S wrote:
>> That sounds similar to what I had to do with a custom Albers projection
>> for Florida. If I recall correctly, I was able to use the custom
>> parameters from the E$RI definition, and make the same custom projection
>> in GRASS to work with the data.
> Mark,
> So, it may be related to using customized parameters. OK. I can live with
> that.
> I plan on importing each theme into a different location/map set, then
> creating a common one into which I will reproject/move/whatever each
> individual theme. Then I should be able to remove all those directories.
> Step-by-step I make progress.
> BTW, in the late 1980's I was a Technical Program Manager for the St.
> Johns River Water Management District. That's where I was first introduced
> to GIS (ARC/Info running on the Prime system there).
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
