[GRASS-user] E00 import problem
Markus Neteler
neteler at osgeo.org
Sun Nov 22 03:10:34 EST 2009
Richard,
downloaded and tested:
# uncompress
e00conv dnnet.e00 24647.e00
# convert
avcimport 24647.e00 dnnet
# look at metadata:
ogrinfo -so dnnet arc
Had to open data source read-only.
INFO: Open of `dnnet'
using driver `AVCBin' successful.
Layer name: ARC
Geometry: Line String
Feature Count: 59798
Extent: (-4774718.500000, 7619798.000000) - (-1109733.750000, 10478012.000000)
Layer SRS WKT:
PROJCS["unnamed",
GEOGCS["Unknown datum based upon the Clarke 1866 ellipsoid",
DATUM["Not_specified_based_on_Clarke_1866_ellipsoid",
SPHEROID["Clarke 1866",6378206.4,294.9786982139006,
AUTHORITY["EPSG","7008"]],
AUTHORITY["EPSG","6008"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.01745329251994328,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4008"]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",70],
PARAMETER["standard_parallel_2",50],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",110],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["METERS",1]]
UserId: Integer (0.0)
FNODE_: Integer (0.0)
TNODE_: Integer (0.0)
LPOLY_: Integer (0.0)
RPOLY_: Integer (0.0)
LENGTH: Real (12.3)
DNNET#: Integer (5.0)
DNNET-ID: Integer (5.0)
DNLNTYPE: Integer (2.0)
DNLNSTAT: Integer (2.0)
http://www.maproom.psu.edu/cgi-bin/dcw/dcwarea.cgi?Asia
states
Projection information for Russia
Projection LAMBERT
Units METERS
Spheroid CLARKE1866
So you cannot import this into a LatLong location but need to
create a Lambert projected location.
The metadata in the uncompressed E00 file contain:
PRJ 2
Projection LAMBERT
Zunits NO
Units METERS
Spheroid CLARKE1866
Xshift 0.0000000000
Yshift 0.0000000000
Parameters
70 0 0.000 /* 1st standard parallel
50 0 0.000 /* 2nd standard parallel
110 0 0.000 /* central meridian
0 0 0.000 /* latitude of projection's origin
0.00000 /* false easting (meters)
0.00000 /* false northing (meters)
With the Location manager, you will be able to define it.
The v.in.e00 will work as expected.
Markus
