[GRASS-user] E00 import problem
Richard Chirgwin
rchirgwin at ozemail.com.au
Sun Nov 22 15:53:14 EST 2009
Markus,
As always, thanks!
Richard
Markus Neteler wrote:
> Richard,
> downloaded and tested:
> # uncompress
> e00conv dnnet.e00 24647.e00
> # convert
> avcimport 24647.e00 dnnet
> # look at metadata:
> ogrinfo -so dnnet arc
> Had to open data source read-only.
> INFO: Open of `dnnet'
> using driver `AVCBin' successful.
> Layer name: ARC
> Geometry: Line String
> Feature Count: 59798
> Extent: (-4774718.500000, 7619798.000000) - (-1109733.750000, 10478012.000000)
> Layer SRS WKT:
> PROJCS["unnamed",
> GEOGCS["Unknown datum based upon the Clarke 1866 ellipsoid",
> DATUM["Not_specified_based_on_Clarke_1866_ellipsoid",
> SPHEROID["Clarke 1866",6378206.4,294.9786982139006,
> AUTHORITY["EPSG","7008"]],
> AUTHORITY["EPSG","6008"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.01745329251994328,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4008"]],
> PROJECTION["Lambert_Conformal_Conic_2SP"],
> PARAMETER["standard_parallel_1",70],
> PARAMETER["standard_parallel_2",50],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",110],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> UNIT["METERS",1]]
> UserId: Integer (0.0)
> FNODE_: Integer (0.0)
> TNODE_: Integer (0.0)
> LPOLY_: Integer (0.0)
> RPOLY_: Integer (0.0)
> LENGTH: Real (12.3)
> DNNET#: Integer (5.0)
> DNNET-ID: Integer (5.0)
> DNLNTYPE: Integer (2.0)
> DNLNSTAT: Integer (2.0)
> http://www.maproom.psu.edu/cgi-bin/dcw/dcwarea.cgi?Asia
> states
> Projection information for Russia
> Projection LAMBERT
> Units METERS
> Spheroid CLARKE1866
> So you cannot import this into a LatLong location but need to
> create a Lambert projected location.
> The metadata in the uncompressed E00 file contain:
> PRJ 2
> Projection LAMBERT
> Zunits NO
> Units METERS
> Spheroid CLARKE1866
> Xshift 0.0000000000
> Yshift 0.0000000000
> Parameters
> 70 0 0.000 /* 1st standard parallel
> 50 0 0.000 /* 2nd standard parallel
> 110 0 0.000 /* central meridian
> 0 0 0.000 /* latitude of projection's origin
> 0.00000 /* false easting (meters)
> 0.00000 /* false northing (meters)
> With the Location manager, you will be able to define it.
> The v.in.e00 will work as expected.
> Markus
