[GRASS-user] v.db.join - created fields with only one character long
Luís Ferreira
lferreira75.1 at gmail.com
Sun Nov 22 16:00:23 EST 2009
When trying to join a vector table with another table, the created
fields are only type character(1). The original fields to import vary
from 1 to 100 characters.
Is this a bug or I'm not doing something previously necessary?
GRASS 6.4 rev 39766 from SVN
postgresql 8.4.1 from repository
Ubuntu 9.10
Luís Ferreira
v.db.join map=cos90_clean at cos90 column=leg otable=grass.cos90rcl
ocolumn=codigo
DBMI-Postgres driver error:
Cannot execute:
UPDATE grass.cos90_clean SET codigo=(SELECT codigo
FROM grass.cos90rcl WHERE
grass.cos90rcl.codigo=grass.cos90_clean.leg)
ERROR: value too long for type character(1)
ERROR: Error while executing: 'UPDATE grass.cos90_clean SET
FROM grass.cos90rcl WHERE grass.cos90rcl.codigo=grass.cos90_clean.leg)'
Cannot execute:
UPDATE grass.cos90_clean SET leg2=(SELECT leg2
ERROR: Error while executing: 'UPDATE grass.cos90_clean SET leg2=(SELECT
leg2
Cannot execute:
UPDATE grass.cos90_clean SET nivel1=(SELECT nivel1
etc.
