[GRASS-user] Reprojecting Vector Map
Pablo Carreira pablotcarreira at hotmail.com
Tue Nov 24 19:35:31 EST 2009
>    The wxPython GUI has a bug: when UTM is specified as the projection, we
> cannot change the zone from the default 30...
Today a have seen this bug in wx, it looks like the zone box is hidden.
You may create a custom proj.4 parameters to bypass this problem
Look at this site: http://spatialreference.org/
It has all the parameters ready for use.
Pablo Torres Carreira
> Date: Tue, 24 Nov 2009 14:48:41 -0800
> From: rshepard at appl-ecosys.com
> To: grass-users at lists.osgeo.org
> Subject: RE: [GRASS-user] Reprojecting Vector Map
> CC:
> On Tue, 24 Nov 2009, Pablo Carreira wrote:
> > Assumptions:
> > -Very well defined LOCATION parameters is the foundation to perfectly combine maps of different sources.
> > -The experience tells me that some data are even in the correct reference system, but sometimes the "info" that comes with it sometimes not.
> > -Each coutry has it's adequated reference system.
> > -GIS and GPS comes with a lot of reference systems, but they follow an international standard.
> > -Those standards sometimes differ a little from the "real parameters".
> Pablo,
>    Thanks for your contributions. I think that I have this correctly handled
> now.
>    My raster (DEM) layer covers the northwest portion of the state, the
> hydrologic unit boundaries (level 6) and dams are statewide. These three are
> lcc projection. Soils and streets are for a specific county. The former is
> UTM Zone 10, the latter lat/long.
>    The soils data are in .e00 format, but without the projection/datum
> information in the header.
> cannot change the zone from the default 30. The Tcl/Tk GUI didn't ask me to
> specify a projection. I commented out most lines in ~/.grassrc6 and worked
> in the original, ugly, user-unfriendly VT100 interface. With numerous errors
> and use of the arrow keys I was able to enter all relevant information
> except for the e-w and n-s resolutions. The metadata file specifies those as
> 0 but GRASS64svn won't take that value. I had to use 1 instead. Shrug.
>    Once I had the soils/PERMANENT location defined I exited grass, restored
> the rc file, and restarted it. Using the wxPython UI I defined the mapset
> and imported the mapping unit areas, line features, and point features.
>    Then I created a new location and defined it as LCC. From within that new
> location I ran v.proj and converted the three soils layers. 'g.region -p'
> appears to display correct coordinates.
>    Now I need to re-do the streets and see if I can get that layer
> reprojected from LL to LCC. So far it's fighting me and winning.
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
_________________________________________________________________
Novo windowslive.com.br. Descubra como juntar a galera com os produtos Windows Live.
http://www.windowslive.com.br/?ocid=WindowsLive09_MSN_Hotmail_Tagline_out09
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091124/6c7fc057/attachment.html
