[GRASS-user] Re: r.mapcalc changes color table
Glynn Clements
glynn at gclements.plus.com
Fri Nov 27 19:32:20 EST 2009
Hermann Peifer wrote:
> >> I have a large georeferenced digital map.
> >> I successfully imported it into GRASS.
> >> Now I would like to "cut" only a small rectangle -- my investigation
> >> area -- out of this large map.
> >> I used the following approach:
> >> 1) import the TIFF
> >> 2) select the part of interest in the GRASS monitor
> >> 3) set the zoomed area as region (monitor tools)
> >> 4) create a boundary vector: v.in.region
> >> 5) convert boundary raster to a raster v.to.rast
> >> 6) use r.mapcalc to cut: r.mapcalc "cut=if(boundary_raster, large_map,
> >> null())"
> > Replace step 6 with:
> > g.copy rast=boundary_raster,MASK
> > r.resample input=large_map output=cut
> > g.remove rast=MASK
> Can someone perhaps explain why steps 4 and 5 are necessary?
> (My understanding is that r.mapcalc anyway observes the region settings)
I wasn't paying attention. For a rectangular area, you can just change
the region then make a copy with r.resample or r.mapcalc. I was
assuming an arbitrary (not necessarily rectangular) region.
For a rectangular region, steps 3 through 6 can be replaced with a
single call to r.resample.
> Couldn't step 6 be simplified to: r.mapcalc cut = large_map
Which is equivalent to "r.resample in=large_map out=cut". Using
r.resample is probably more convenient from the GUI, as you can select
the input from a list.
