[GRASS-user] r.walk [Fwd: Re: [GRASS-stats] r.cost]
Agustin Lobo
alobolistas at gmail.com
Fri Nov 27 04:09:40 EST 2009
-------- Original Message --------
Subject: Re: [GRASS-stats] r.cost
Date: Thu, 26 Nov 2009 20:15:34 +0100
Reply-To: Agustin.Lobo at ija.csic.es
To: Jarek Jasiewicz <jarekj at amu.edu.pl>
CC: Agustin.Lobo at ija.csic.es, GRASS STATS <grass-stats at lists.osgeo.org>
References: <4B0EBCB2.1080700 at gmail.com> <4B0EC072.6020709 at amu.edu.pl>
Yes, thanks, r.walk is the appropriate module.
In case there are several starting coordinates, how are the different
costs combined? the lowest as in r.cost?
Agus
Jarek Jasiewicz wrote:
> Agustin Lobo pisze:
>> Hi!
>> Is there any way to weight the accumulation in r.cost
>> so that going uphill is harder than going downhill?
>> Thanks
>> Agus
>> grass-stats mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
> seems that r.walk could be the answer
> J.
