[GRASS-user] v.to.rast Segmentation fault
Markus Neteler neteler at osgeo.org
Sat Nov 28 16:03:40 EST 2009
On Fri, Nov 27, 2009 at 5:33 PM, Giacomo Piva <piva at meeo.it> wrote:
> Hi all,
> I just installed the grass distribution with version 6.4.0 RC5 on a linux
> box (Ubuntu 9.10) downloaded from the website. (not cvs)
> I'm trying to work with the "v.to.ras" module as a CLI and I'm unsing this
> command to get some help message:
> /usr/local/grass-6.4.0RC5/bin/v.to.rast help
> and... the result is a wonderful Segmentation fault.
> Does someone has any idea?
Please check
ldd `which v.to.rast`
I suspect that you have GDAL 1.5.x there which apparently
causes problems on Ubuntu (update to 1.6.x helps).
Markus
