[GRASS-user] v.to.rast Segmentation fault
Giacomo Piva piva at meeo.it
Mon Nov 30 07:39:57 EST 2009
Hi Markus,
Thanks for your reply.
The current GDAL installed is the version 1.6.0 (released 2008/12/04)
and I did run the lddconfig because the libgrass_vect.so was not found.
Since the result of the "not found" ldd is empty, it seems there is't
problems with shared libraries.
Do you have any suggestion?
Markus Neteler wrote:
> On Fri, Nov 27, 2009 at 5:33 PM, Giacomo Piva <piva a meeo.it> wrote:
>> Hi all,
>> I just installed the grass distribution with version 6.4.0 RC5 on a linux
>> box (Ubuntu 9.10) downloaded from the website. (not cvs)
>> I'm trying to work with the "v.to.ras" module as a CLI and I'm unsing this
>> command to get some help message:
>> /usr/local/grass-6.4.0RC5/bin/v.to.rast help
>> and... the result is a wonderful Segmentation fault.
>> Does someone has any idea?
> Please check
> ldd `which v.to.rast`
> I suspect that you have GDAL 1.5.x there which apparently
> causes problems on Ubuntu (update to 1.6.x helps).
> Markus
Giacomo Piva
MEEO S.r.l.
Via Saragat 9
I-44122 Ferrara, Italy
Tel: +39 0532 1861501
Fax: +39 0532 1861637
http://www.meeo.it
"ATTENZIONE:le informazioni contenute in questo messaggio sono
da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
per errore è tenuto ad informare il mittente ed a rimuoverlo
definitivamente da ogni supporto elettronico o cartaceo."
"WARNING:This message contains confidential and/or proprietary
information which may be subject to privilege or immunity and which
is intended for use of its addressee only. Should you receive this
message in error, you are kindly requested to inform the sender and
to definitively remove it from any paper or electronic format."
