[GRASS-user] v.to.rast Segmentation fault
    Markus Metz
    markus.metz.giswork at googlemail.com
    Mon Nov 30 08:03:58 EST 2009
Hi Giacomo,
are you by any chance running this command outside a GRASS session? If
grass is running, there is no need to give the full path, typing
v.to.rast help
in the terminal where grass is running is enough. Also, grass should
know where to look for libgrass_vect.so, no need to run ldconfig. If you
really want to use grass modules outside a standard grass session, see
the grass book [1], third edition, page 338, 9.3 Automated usage of GRASS.
Hope that helps,
Markus M
[1] http://www.grassbook.org/
Giacomo Piva wrote:
> Hi Markus,
> Thanks for your reply.
> The current GDAL installed is the version 1.6.0 (released 2008/12/04)
> and I did run the lddconfig because the libgrass_vect.so was not found.
> Since the result of the "not found" ldd is empty, it seems there is't
> problems with shared libraries.
> Do you have any suggestion?
> Markus Neteler wrote:
>> On Fri, Nov 27, 2009 at 5:33 PM, Giacomo Piva <piva at meeo.it> wrote:
>>> Hi all,
>>> I just installed the grass distribution with version 6.4.0 RC5 on a
>>> linux
>>> box (Ubuntu 9.10) downloaded from the website. (not cvs)
>>> I'm trying to work with the "v.to.ras" module as a CLI and I'm
>>> unsing this
>>> command to get some help message:
>>> /usr/local/grass-6.4.0RC5/bin/v.to.rast help
>>> and... the result is a wonderful Segmentation fault.
>>> Does someone has any idea?
>> Please check
>> ldd `which v.to.rast`
>> I suspect that you have GDAL 1.5.x there which apparently
>> causes problems on Ubuntu (update to 1.6.x helps).
>> Markus
