[GRASS-user] wxGui query raster/vector
    Martin Landa
    landa.martin at gmail.com
    Fri Oct  2 15:30:33 EDT 2009
2009/10/2 Paolo Craveri <pcraveri at gmail.com>:
> 1) load a vector maps (e.g. archsites from spearfish)
> 2) display it in map display
> 3) query raster/vector (display mode)
> 4) in layer manager, command output, I get this error:
>  “ERROR: You must build topology on vector map <archsites at PERMANENT>”
> No errors with grass 6.4 RC5.
probably related to the spatial index changes in GRASS 7.0(?). You
need to rebuild topology using v.build or v.build.all (this will
create spatial index file).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
