[GRASS-user] CYGWIN
Glynn Clements
glynn at gclements.plus.com
Sat Oct 3 17:25:26 EDT 2009
Markus Neteler wrote:
> Thanks for the background.
> At this point I only see the possibility to split the previously
> convenient one-pass installation into a two-pass installation:
> 1. install cygwin
> 2. start cmd.exe and run setup.exe with -X (needs full path I guess?)
> Any better solution possible?
Create a shortcut for the setup program and add -X to the command.
This saves having to type out the full path to setup.exe in the
command prompt.
I don't think that we can automate this, as you don't know where
setup.exe will live; it doesn't get installed within the Cygwin tree.
