[GRASS-user] CYGWIN
    Markus Neteler
    neteler at osgeo.org
    Sun Oct  4 13:57:29 EDT 2009
On Sat, Oct 3, 2009 at 11:25 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> Any better solution possible?
> Create a shortcut for the setup program and add -X to the command.
> This saves having to type out the full path to setup.exe in the
> command prompt.
Ah, ok. I have added it to the explanations at
http://grass.osgeo.org/grass64/binary/mswindows/cygwin
@Windows users:
It needs to be revised. Ideally tested by a novice with comments
to me/to the list... just tell us if it works and if it is clear like this.
If not (likely), please suggest how to improve it.
Markus
