[GRASS-user] gis.m crashes at startup
    Margherita Di Leo
    diregola at gmail.com
    Wed Oct  7 10:56:17 EDT 2009
Hi List!
I've a problem running grass 6.5 svn on Ubuntu 8.04 64 bit (just installed).
When entering a location, gis.m crashes and in terminal it writes:
GRASS 6.5.svn (brenta):~ > Error in startup script: can't read "prj(proj)":
no such variable
    while executing
"if { $prj(proj) == "ll"} {set proj_is_ll 1}"
    (procedure "MapCanvas::get_mapunits" line 22)
    invoked from within
    (procedure "MapCanvas::create" line 37)
    invoked from within
"MapCanvas::create"
    (procedure "Gm::startmon" line 11)
    invoked from within
"Gm::startmon"
    (procedure "Gm::create" line 79)
    invoked from within
"Gm::create"
    (procedure "main" line 30)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-6.5.svn/etc/gm/gm.tcl" line 602)
Any idea?
Thank you in advance
Margherita
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091007/8807aaa6/attachment.html
