[GRASS-user] gis.m crashes at startup
    Michael Barton
    michael.barton at asu.edu
    Wed Oct  7 12:11:04 EDT 2009
On Oct 7, 2009, at 9:00 AM, grass-user-request at lists.osgeo.org wrote:
> Date: Wed, 7 Oct 2009 16:56:17 +0200
> From: Margherita Di Leo <diregola at gmail.com>
> Subject: [GRASS-user] gis.m crashes at startup
> To: grass-user at lists.osgeo.org
> Message-ID:
> 	<730a39860910070756p20c2685ayaeb89d47f4a37372 at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi List!
> I've a problem running grass 6.5 svn on Ubuntu 8.04 64 bit (just
> installed).
> When entering a location, gis.m crashes and in terminal it writes:
> GRASS 6.5.svn (brenta):~ > Error in startup script: can't read
> "prj(proj)":
> no such variable
>    while executing
> "if { $prj(proj) == "ll"} {set proj_is_ll 1}"
>    (procedure "MapCanvas::get_mapunits" line 22)
>    invoked from within
>    (procedure "MapCanvas::create" line 37)
>    invoked from within
> "MapCanvas::create"
>    (procedure "Gm::startmon" line 11)
>    invoked from within
> "Gm::startmon"
>    (procedure "Gm::create" line 79)
>    invoked from within
> "Gm::create"
>    (procedure "main" line 30)
>    invoked from within
> "main $argc $argv"
>    (file "/usr/local/grass-6.5.svn/etc/gm/gm.tcl" line 602)
> Any idea?
You probably have a problem with your installation of gdal. In the
terminal, try g.region -gp. This probably won't work, indicating a
gdal (or possible PROJ) problem.
Michael
