[GRASS-user] Re: grass-user Digest, Vol 42, Issue 14
    Margherita Di Leo
    diregola at gmail.com
    Thu Oct  8 17:33:08 EDT 2009
Michael,
thank you for answering. I tried to remove and then reinstall gdal and
proj4, then recompiled grass, with the same result. In text mode, grass
works and answers at :
GRASS 6.5.svn (spearfish60):~ > g.region -gp
n=4928000
s=4914020
w=590010
e=609000
nsres=30
ewres=30
rows=466
cols=633
cells=294978
but in tclck i have the same problem i had before.
Margherita
> Date: Wed, 7 Oct 2009 09:11:04 -0700
> From: Michael Barton <michael.barton at asu.edu>
> Subject: Re: [GRASS-user] gis.m crashes at startup
> To: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
> Message-ID: <BE94782D-F584-475A-9B37-5302EE547DCF at asu.edu>
> Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yes
> On Oct 7, 2009, at 9:00 AM, grass-user-request at lists.osgeo.org wrote:
> > Date: Wed, 7 Oct 2009 16:56:17 +0200
> > From: Margherita Di Leo <diregola at gmail.com>
> > Subject: [GRASS-user] gis.m crashes at startup
> > To: grass-user at lists.osgeo.org
> > Message-ID:
> >       <730a39860910070756p20c2685ayaeb89d47f4a37372 at mail.gmail.com>
> > Content-Type: text/plain; charset="iso-8859-1"
> > Hi List!
> > I've a problem running grass 6.5 svn on Ubuntu 8.04 64 bit (just
> > installed).
> > When entering a location, gis.m crashes and in terminal it writes:
> > GRASS 6.5.svn (brenta):~ > Error in startup script: can't read
> > "prj(proj)":
> > no such variable
> >    while executing
> > "if { $prj(proj) == "ll"} {set proj_is_ll 1}"
> >    (procedure "MapCanvas::get_mapunits" line 22)
> >    invoked from within
> >    (procedure "MapCanvas::create" line 37)
> >    invoked from within
> > "MapCanvas::create"
> >    (procedure "Gm::startmon" line 11)
> >    invoked from within
> > "Gm::startmon"
> >    (procedure "Gm::create" line 79)
> >    invoked from within
> > "Gm::create"
> >    (procedure "main" line 30)
> >    invoked from within
> > "main $argc $argv"
> >    (file "/usr/local/grass-6.5.svn/etc/gm/gm.tcl" line 602)
> > Any idea?
> You probably have a problem with your installation of gdal. In the
> terminal, try g.region -gp. This probably won't work, indicating a
> gdal (or possible PROJ) problem.
> Michael
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091008/b258a2bc/attachment.html
