[GRASS-user] Re: grass-user Digest, Vol 42, Issue 14
Hamish
hamish_b at yahoo.com
Thu Oct 8 19:04:07 EDT 2009
Margherita wrote:
> thank you for answering. I tried to remove and then
> reinstall gdal and proj4, then recompiled grass, with the
> same result. In text mode, grass works and answers at :
> GRASS 6.5.svn (spearfish60):~ > g.region -gp
> n=4928000
> s=4914020
> w=590010
> e=609000
> nsres=30
> ewres=30
> rows=466
> cols=633
> cells=294978
> but in tclck i have the same problem i had before.
> > I've a problem running grass 6.5 svn on Ubuntu 8.04 64 bit (just
> > installed).
are you using the packages from ppa.launchpad.net/ubuntugis ?
> > When entering a location, gis.m crashes and in terminal it writes:
> > GRASS 6.5.svn (brenta):~ > Error in startup script: can't read
> > "prj(proj)": no such variable
> > while executing
> > "if { $prj(proj) == "ll"} {set proj_is_ll 1}"
> > (procedure "MapCanvas::get_mapunits" line 22)
what does "g.proj -p" say?
Hamish
