[GRASS-user] Re: grass-user Digest, Vol 42, Issue 14
Margherita Di Leo
diregola at gmail.com
Fri Oct 9 03:12:05 EDT 2009
Hi Hamish,
2009/10/9 Hamish <hamish_b at yahoo.com>
> > > I've a problem running grass 6.5 svn on Ubuntu 8.04 64 bit (just
> > > installed).
> are you using the packages from ppa.launchpad.net/ubuntugis ?
no, i used http://les-ejk.cz/ubuntu/ (for Hardy).
> > > When entering a location, gis.m crashes and in terminal it writes:
> > > GRASS 6.5.svn (brenta):~ > Error in startup script: can't read
> > > "prj(proj)": no such variable
> > > while executing
> > > "if { $prj(proj) == "ll"} {set proj_is_ll 1}"
> > > (procedure "MapCanvas::get_mapunits" line 22)
> what does "g.proj -p" say?
> GRASS 6.5.svn (spearfish60):~ > g.proj -p
-PROJ_INFO-------------------------------------------------
datum : nad27
nadgrids : conus
proj : utm
ellps : clark66
a : 6378206.4000000004
es : 0.0067686580
f : 294.9786982000
zone : 13
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1.0
> Hamish
> Thank you.
Margherita
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091009/d6c14cda/attachment.html
