[GRASS-user] Re: gis.m crashes at startup (SOLVED)
    Margherita Di Leo
    diregola at gmail.com
    Fri Oct  9 08:02:30 EDT 2009
 I solved changing repository.
Thank you.
Margherita
2009/10/8 Margherita Di Leo <diregola at gmail.com>
> Michael,
> thank you for answering. I tried to remove and then reinstall gdal and
> proj4, then recompiled grass, with the same result. In text mode, grass
> works and answers at :
> GRASS 6.5.svn (spearfish60):~ > g.region -gp
> n=4928000
> s=4914020
> w=590010
> e=609000
> nsres=30
> ewres=30
> rows=466
> cols=633
> cells=294978
> but in tclck i have the same problem i had before.
> Margherita
>> Date: Wed, 7 Oct 2009 09:11:04 -0700
>> From: Michael Barton <michael.barton at asu.edu>
>> Subject: Re: [GRASS-user] gis.m crashes at startup
>> To: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
>> Message-ID: <BE94782D-F584-475A-9B37-5302EE547DCF at asu.edu>
>> Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yes
>> On Oct 7, 2009, at 9:00 AM, grass-user-request at lists.osgeo.org wrote:
>> > Date: Wed, 7 Oct 2009 16:56:17 +0200
>> > From: Margherita Di Leo <diregola at gmail.com>
>> > Subject: [GRASS-user] gis.m crashes at startup
>> > To: grass-user at lists.osgeo.org
>> > Message-ID:
>> >       <730a39860910070756p20c2685ayaeb89d47f4a37372 at mail.gmail.com>
>> > Content-Type: text/plain; charset="iso-8859-1"
>> > Hi List!
>> > I've a problem running grass 6.5 svn on Ubuntu 8.04 64 bit (just
>> > installed).
>> > When entering a location, gis.m crashes and in terminal it writes:
>> > GRASS 6.5.svn (brenta):~ > Error in startup script: can't read
>> > "prj(proj)":
>> > no such variable
>> >    while executing
>> > "if { $prj(proj) == "ll"} {set proj_is_ll 1}"
>> >    (procedure "MapCanvas::get_mapunits" line 22)
>> >    invoked from within
>> >    (procedure "MapCanvas::create" line 37)
>> >    invoked from within
>> > "MapCanvas::create"
>> >    (procedure "Gm::startmon" line 11)
>> >    invoked from within
>> > "Gm::startmon"
>> >    (procedure "Gm::create" line 79)
>> >    invoked from within
>> > "Gm::create"
>> >    (procedure "main" line 30)
>> >    invoked from within
>> > "main $argc $argv"
>> >    (file "/usr/local/grass-6.5.svn/etc/gm/gm.tcl" line 602)
>> > Any idea?
>> You probably have a problem with your installation of gdal. In the
>> terminal, try g.region -gp. This probably won't work, indicating a
>> gdal (or possible PROJ) problem.
>> Michael
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091009/65801d1b/attachment.html
