[GRASS-user] Maximum number of parameters
Ned Horning
horning at amnh.org
Fri Oct 9 12:41:08 EDT 2009
I am writing a script that calibrates a 6-band image using slope and
intercept values but am having a problem reading these values from the
command line. In total the script expects 14 parameters to be entered at
the command line but is seems as if only 9 are accepted. Is that a
limitation of GRASS? I only tested this using the Windows version. Are
there alternatives for inputing more than 9 parameters for a script
other than directly adding the slope and aspect parameters into the script?
Ned
