[GRASS-user] Re: Maximum number of parameters
Hermann Peifer
peifer at gmx.eu
Fri Oct 9 13:02:08 EDT 2009
Try ${10}, ${11},... instead of $10, $11, ...
Hermann
-------- Original Message --------
Subject: Maximum number of parameters
To:
Date: 09/10/2009 18:41
> I am writing a script that calibrates a 6-band image using slope and
> intercept values but am having a problem reading these values from the
> command line. In total the script expects 14 parameters to be entered at
> the command line but is seems as if only 9 are accepted. Is that a
> limitation of GRASS? I only tested this using the Windows version. Are
> there alternatives for inputing more than 9 parameters for a script
> other than directly adding the slope and aspect parameters into the script?
> Ned
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
