[GRASS-user] Missing some tools: v.db.addcol, for example
    Roger André
    randre at gmail.com
    Wed Oct 14 20:45:19 EDT 2009
Hi GRASS list,
I've noticed that a few tools in my GRASS 6.4 appear to be missing, or
at least missing from my path.  Here is an example:
GRASS 6.4.0RC4 (colombia):~/> v.db.addcol countries_simpl col="diss int(1)"
bash: v.db.addcol: command not found
And yet, when I look for the tool under my install dir, it appears to be there:
$ find /usr/local/grass-6.4.0RC4 -name "v.db.addcol*"
/usr/local/grass-6.4.0RC4/docs/html/v.db.addcol.html
/usr/local/grass-6.4.0RC4/locale/scriptstrings/v.db.addcol_to_translate.c
/usr/local/grass-6.4.0RC4/man/man1/v.db.addcol.1
/usr/local/grass-6.4.0RC4/scripts/v.db.addcol
/usr/local/grass-6.4.0RC4/scripts/v.db.addcol/v.db.addcol
/usr/local/grass-6.4.0RC4/scripts/v.db.addcol/v.db.addcol.tmp.html
/usr/local/grass-6.4.0RC4/dist.i686-pc-linux-gnu/docs/html/v.db.addcol.html
/usr/local/grass-6.4.0RC4/dist.i686-pc-linux-gnu/man/man1/v.db.addcol.1
/usr/local/grass-6.4.0RC4/dist.i686-pc-linux-gnu/scripts/v.db.addcol
It's only a problem with certain tools.  I have the same problem with
d.redraw for example, but not with d.erase.  The difference seems to
be that d.erase is not under the scripts dir, but is instead in bin
(all under GRASS of course).
Is there some way I can add the scripts tools back in, and is this the
sign that I just screwed up the install somehow?
Thanks,
Roger
