[GRASS-user] r.basins.fill usage
Achim Kisseler
ak7 at jupiter.uni-freiburg.de
Thu Oct 15 09:27:02 EDT 2009
I'm not sure if I understood you right:
the border of a watershed is unique, if you see the basin starting from
outlet of a river into the ocean.
But there are unlimited subbasins (up to the resolution of the raster)!
So you have to define a characteristic for the watersheds, eg. a basin
size from the threshold of r.watershed.
Greets,
Achim
M S schrieb:
> Upon first glance, r.basins.fill seems like a great tool to generate
> subbasins within a watershed. Although I must not be understanding
> something obvious and essential.
> If one has to digitize in the internal ridges in a given watershed,
> why run the ridge input through the module if one has essentially just
> delineated the subbasins ridges?
> Is there an advantage to using a smaller threshold on r.watershed to
> get smaller basin delineations (ceasing when thin strip basins get
> introduced)?
> Thanks for any feedback,
> Mark
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
