[GRASS-user] r.basins.fill usage
MS
mseibel at gmail.com
Thu Oct 15 11:09:24 EDT 2009
The man page seems to imply that internal divided need digitized?
Much thanks,
Mark
On Oct 15, 2009, at 9:27 AM, Achim Kisseler <ak7 at jupiter.uni-
freiburg.de> wrote:
> I'm not sure if I understood you right:
> the border of a watershed is unique, if you see the basin starting
> from
> outlet of a river into the ocean.
> But there are unlimited subbasins (up to the resolution of the
> raster)!
> So you have to define a characteristic for the watersheds, eg. a basin
> size from the threshold of r.watershed.
> Greets,
> Achim
> M S schrieb:
>> Upon first glance, r.basins.fill seems like a great tool to generate
>> subbasins within a watershed. Although I must not be understanding
>> something obvious and essential.
>> If one has to digitize in the internal ridges in a given watershed,
>> why run the ridge input through the module if one has essentially
>> just
>> delineated the subbasins ridges?
>> Is there an advantage to using a smaller threshold on r.watershed to
>> get smaller basin delineations (ceasing when thin strip basins get
>> introduced)?
>> Thanks for any feedback,
>> Mark
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
