[GRASS-user] Re: GRASS 6.4 Questions
Scott Mitchell smitch at mac.com
Thu Oct 15 10:30:09 EDT 2009
On 15-Oct-2009, at 09:45 , Andrew Davidson wrote:
> Can you direct this query to someone who might be able to answer it?
> From: John Caudill[SMTP:JOHNCATLGEO at BELLSOUTH.NET]
> Sent: Wednesday, October 14, 2009 4:18:40 PM
> To: Davidson, Andrew
> Subject: GRASS 6.4 Questions
> Dear Mr. Davidson:
> Your the only email I can find for GRASS questions.  I just downloaded
> version 6.4.  I can't get it to open any data set.  I may have
> downloaded the Spearfish data wrong? or its in the wrong file or
> whatever.  When I hit the Welcome button, I can only get a blank
> screen
> with the display page with the icons at the top.  On the next "page" I
> can find no place where I can download a map layer.... anywhere.  None
> of the tutorials show how to call up the data.  I must be doing
> something very wrong.
> HELP
> John Caudill, PE the DATABASE
> Atlantic Geoscience, Inc.
> Watkinsville, GA
Hi, John,
The best address for general GRASS help is the GRASS User's mailing
list - see
http://lists.osgeo.org/mailman/listinfo/grass-user
for instructions on how to read archives, post, and sign up.
As a start towards your problem, however, I can offer the following
(you haven't said what operating system you're using, so the tips here
are somewhat generic):
This first database selection step does confuse many new users.  You
need to expand the Spearfish data archive first, if you haven't
already - it can't still be in the .zip or .tar.gz file that you
received it in.  How you do this expansion step depends on your
operating system, but on most modern machines just double clicking on
it will at least offer some alternative.  This should result in an
expanded directory structure being extracted, all under a top level
directory called spearfish60.  Then back in the GRASS startup, the
DATABASE is the directory under which you stored that expanded
directory, the LOCATION in this case would be spearfish60, and you
have the choice of PERMANENT or user1 for the MAPSET, and user1 is the
recommended choice.
One place, among others, to see an explanation of what these
parameters are referring to is the web page at:
http://grass.osgeo.org/grass64/manuals/html64_user/helptext.html
I hope that helps, if not please follow up on the GRASS users mailing
list.
Scott Mitchell
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091015/e33512d6/attachment.html
