[GRASS-user] Missing some tools: v.db.addcol, for example
Markus Neteler
neteler at osgeo.org
Fri Oct 16 05:44:36 EDT 2009
On Thu, Oct 15, 2009 at 5:00 PM, Roger André <randre at gmail.com> wrote:
> Thanks,
> My PATH while in GRASS already contains the scripts dir:
> GRASS 6.4.0RC4 (colombia):~ > echo $PATH
> /usr/local/grass-6.4.0RC4/bin:/usr/local/grass-6.4.0RC4/scripts:<snip>
> What I did find is that each script is under a directory by the same
> name in the scripts dir. So for example, d.redraw is in:
> /usr/local/grass-6.4.0RC4/scripts/d.redraw/d.redraw
Wow. This is not desired of course. I am a bit surprised.
> I'm going through all of these now, and removing the dir and leaving
> the script. Somewhat tedious, but the scripts appear to work.
Would you mind to check if this is still valid for RC5?
Markus
